Admin Console crashing or ISY994i rebooting itself
Here are some symptoms:
Admin Console unresponsive
error box but all white
login box
login box but all white
To recover from this, on my windows computer, I close the Java process with the Task Manager.  This is pretty annoy, especially since I'm trying to debug some weird stuff going on with the Z-Wave.  This could be related.
I thought this might have been related to my unsuccessful attempt at using Polyglot 2.7.  I backed up my configuration and did a factory reset.  I also factory reset the PLM.  I restored the configuration and restored the PLM.  This had little affect.
Perhaps you know this poltergeist?
Gregg
from error log:
Sun 2022/03/20 06:25:56 PM    System    -10    n/a
Sun 2022/03/20 06:53:18 PM    System    -5    Start
Sun 2022/03/20 06:53:23 PM    System    -110022    /DEF/F6/I1/NLS/EN_US.TXT
Sun 2022/03/20 06:53:25 PM    System    -7115    ID 002D :err=0, tag='cmd', num=4, nest=4, offse
Sun 2022/03/20 06:53:27 PM    System    -7123    ID 0017 :err=0, tag='control', num=6, nest=6, o
Sun 2022/03/20 06:53:27 PM    System    -7123    ID 0027 :err=0, tag='control', num=6, nest=4, o
Sun 2022/03/20 06:53:28 PM    System    -170001    [Network] Established
Sun 2022/03/20 07:13:00 PM    System    -5011    uuid:0
Sun 2022/03/20 08:01:30 PM    System    -5012    26
Sun 2022/03/20 08:03:03 PM    System    -5    Start
Sun 2022/03/20 08:03:08 PM    System    -110022    /DEF/F6/I1/NLS/EN_US.TXT
Sun 2022/03/20 08:03:10 PM    System    -7115    ID 002D :err=0, tag='cmd', num=4, nest=4, offse
Sun 2022/03/20 08:03:12 PM    System    -7123    ID 0017 :err=0, tag='control', num=6, nest=6, o
Sun 2022/03/20 08:03:12 PM    System    -7123    ID 0027 :err=0, tag='control', num=6, nest=4, o
Sun 2022/03/20 08:03:13 PM    System    -170001    [Network] Established
Sun 2022/03/20 08:12:40 PM    System    -5011    uuid:0
Mon 2022/03/21 08:03:05 AM    System    -100    [DHCP] state=RENEW
Mon 2022/03/21 07:32:53 PM    System    -100    [DHCP] state=RENEW
I also have an IR module
Edited by Old Surfer Dude
the editing box self published.
those are both places the ISY was rebooted.  Did you cause those or did it do it on it's own?
We are on the 22nd now?  has it stabilized? or are you still having issues?
@MrBillThanks for looking.  I can't say for certain if I did those.  I am about 70% confident that I did not do the 8PM one.  I hoping that someone else had seen this and had a solution.
But now I'll be better monitoring the situation and report back with logs
Thanks again
OSD
The ISY does thrash around abit during startup,,, most errors right afterward are normal, but it should simmer down within about 10 minutes.  Not everything in the error log is an error to be worried about, some entries are more informational.
After you reboot the ISY, I'd give it 10 minutes before you try and open the admin console-- let everything get up and running before adding the admin console subscription updates to the mix.
