ELK not running under PG3 3.0.50
@garybixler,
I'm seeing errors as well after updating.  Actually, all node servers are showing the same string of errors.  I sent that information to bpwwer to have him look at it.
6 hours ago, JimboAutomates said:
This is a PG3 issue which seems to affect all NS's, will have to wait for more info from @bpwwer
@JimboAutomates,
bpwwer pushed PG3 3.0.51 which fixed Hue Emulator and some other node servers, but ELK still fails.  My RainMachine node server gives the same errors.  I passed this on to bpwwer.
When I went back to PG3 5.0.46 from PG3 5.0.50 I had to reinstall the ELK NS for it to work again. All other servers worked fine. Everything worked fine again after upgrading to PG3 5.0.51 from PG3 5.0.46 including ELK. In my case I reinstall the ELK NS. Certainly not the best option.
