Fails to start on Polyglot 3.0.50
Since updating to 3.0.50, my HarmonyHub Node server is failing to start. Below is from the log:
2022-03-24 09:13:07,156 MainThread udi_interface      INFO     Controller:__init__: HarmonyController: Initializing
2022-03-24 09:13:07,158 MainThread udi_interface.interface WARNING  interface:db_getNodeDrivers: harmonyctrl not found in database.
2022-03-24 09:13:07,160 MainThread udi_interface.interface INFO     interface:addNode: Adding node HarmonyHub Controller(harmonyctrl) [None]
2022-03-24 09:13:07,162 MainThread udi_interface.interface INFO     interface:setController: Using node "harmonyctrl", driver "ST" for connection status.
2022-03-24 09:13:11,038 MQTT       udi_interface.interface INFO     interface:_message: custom data response {'customparamsdoc': ''}
2022-03-24 09:13:11,086 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = customparamsdoc
2022-03-24 09:13:11,115 Command    udi_interface      ERROR    udi_interface:write: Exception in thread
2022-03-24 09:13:11,117 Command    udi_interface      ERROR    udi_interface:write: Command
2022-03-24 09:13:11,117 Command    udi_interface      ERROR    udi_interface:write: :
2022-03-24 09:13:11,119 Command    udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-03-24 09:13:11,120 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
2022-03-24 09:13:11,128 Command    udi_interface      ERROR    udi_interface:write: self.run()
2022-03-24 09:13:11,129 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run
2022-03-24 09:13:11,132 Command    udi_interface      ERROR    udi_interface:write: self._target(*self._args, **self._kwargs)
2022-03-24 09:13:11,133 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/udi_interface/interface.py", line 678, in _parseInput
2022-03-24 09:13:11,136 Command    udi_interface      ERROR    udi_interface:write: self._handleInput(key, input[key], None)
2022-03-24 09:13:11,137 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/udi_interface/interface.py", line 684, in _handleInput
2022-03-24 09:13:11,141 Command    udi_interface      ERROR    udi_interface:write: self._inConfig(item)
2022-03-24 09:13:11,141 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/udi_interface/interface.py", line 598, in _inConfig
2022-03-24 09:13:11,144 Command    udi_interface      ERROR    udi_interface:write: LOGGER.setLevel(self.currentLogLevel)
2022-03-24 09:13:11,145 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/logging/__init__.py", line 1421, in setLevel
2022-03-24 09:13:11,151 Command    udi_interface      ERROR    udi_interface:write: self.level = _checkLevel(level)
2022-03-24 09:13:11,152 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/logging/__init__.py", line 198, in _checkLevel
2022-03-24 09:13:11,154 Command    udi_interface      ERROR    udi_interface:write: raise ValueError("Unknown level: %r" % level)
2022-03-24 09:13:11,155 Command    udi_interface      ERROR    udi_interface:write: ValueError
2022-03-24 09:13:11,156 Command    udi_interface      ERROR    udi_interface:write: :
2022-03-24 09:13:11,156 Command    udi_interface      ERROR    udi_interface:write: Unknown level: 'NULL'
2022-03-24 09:13:16,667 MQTT       udi_interface.interface INFO     interface:_message: Profile installation finished
I've tried restarting the Node server several times. Also restarting Polyglot and reinstalling the Node server to no avail.
HarmonyHub Version: 3.0.6
Edited by DaveStLou
I have same issue as @DaveStLou and  also with Kasa Node server.
