ISY on Polisy v5.4.2 - OUTDATED
Hello all,
We are very happy to introduce IoP v5.4.2 which is a minor bug fix release and security enhancements.
If you are new to Polisy, please do make sure to review Polisy User Guide
To upgrade, you have a few choices:
- Click the button on the front of the unit only once and wait for the beep
- In the Admin Console, click on Help | Automatically Upgrade Polisy menu
- If you are a geek, ssh and:
sudo pkg update && sudo pkg upgrade && sudo service isy restart
Bug fixes:
- Fixed sunrise sunset UI mismatch
- Removed TPM dependence on flash
- Unnecessary flash usage
- Flash is no longer automatically upgraded to UEFI
- Z-Wave: Added support back for 3 byte config params
Enhancements:
- System editor support for _sys_notify_short allowing node servers to receive notification text in command parameters
https://wiki.universal-devices.com/index.php?title=Polisy_Developers:ISY:API:System_Editors
- Z-Wave: Added support for showing all Z-Wave native links available (in Node Level popup menu and Top level Z-Wave menu)
- Security: Independent security keys are now sealed with the TPM. This allows all clients to use as many different keys as they need ... for instance, each node server can have its own keys that are sealed by the TPM
Important Note:
UEFI upgrade is no longer forced because of variability of the outcome.
  • If the 2nd or 3rd (or both) are constantly blinking, it's best to force upgrade the BIOS on your own by clicking the button on the front 6 times in quick succession
Support Thread:
