Somfy Node Server
Hi
Hi, Just wondering if there would be any interest in creating a Somfy node server on PG3. I think the info can be found here:
somfysystems.com/en-us/somfy-synergy-api
Thanks Gary
Honestly with whatever extra you would buy, the bond bridge and it's NS should work and is probably cost equivalent.
Caveat-i have a bond bridge but not blinds yet. Still building new house.
On 3/29/2022 at 11:21 PM, garybixler said:
Hi
Thanks Gary
Sure if someone builds it.
The bond bridge looks very promising. I think I will go that way. Probably with the pro version because of the direct Ethernet POE connection.
Is there any information about the recommended distance from the bridge device to a Somfy RTS motor?
The specs just say it can cover 2500 sq. ft. and the pro 3500 sq.ft. Just testing with the remote I am able to control a somfy blind 45+ ft. away between floors.
