upgrade to ISY 5.3.4 fails (stalls)
Upgrading from 5.0.16C.
Consistent error, upgrade stalls during the insteon.img file upload, and then shows socket errors as depicted in the second image.
Tried rebooting the ISY, downloading a fresh firmware (left unzipped of course) for the correct version (with PLM).
Also ran the procedure on a different computer, same issue.
Did shut off all virus checking and firewall temporarily (never needed that before).
At least the error is consistent.
Any suggestions?
* Orest
Edited by oskrypuch
OK, thanks, good thread, but still no joy for me.
Added the -Xmx1024m, looks like that gets cleared on updates.
Ensured I cleared the java cache (x3).
Downloaded a fresh start.jnlp file, just to be sure.
Downloaded another copy of 5.3.4.
Identical hang, while trying to update insteon.img.
Perhaps I should try to update to 5.3.2 instead?
Any other thoughts?
* Orest
Edited by oskrypuch
@oskrypuch If you are doing this remotely, I've had this issue as well. You might have better success dong it locally (on the same LAN as the ISY) Other wise the only thing I can think of to try would be to give things a bit more memory. -Xms1024m instead of Xms512m.
If neither of those work, then I'd open a ticket with UDI, they will get you sorted.
Here is my error log, includes a number of attempts to update, and a reboot or two. There are some disconnected modules with pop up no comm errors, that is expected.
Thu 2022/03/31 07:23:02 PM    System    -110020    /TMP/19/insteon.img
Thu 2022/03/31 07:26:30 PM    System    -50001    -6
Thu 2022/03/31 08:15:15 PM    System    -50001    -6
Thu 2022/03/31 08:41:44 PM    System    -50001    -11
Thu 2022/03/31 09:40:43 PM    System    -110020    /TMP/19/insteon.img
Thu 2022/03/31 09:45:06 PM    System    -110020    /TMP/19/insteon.img
Thu 2022/03/31 09:53:15 PM    System    -170001    [UDSockets] RSub:25 error:6
Thu 2022/03/31 09:53:32 PM    System    -5    Start
Thu 2022/03/31 09:53:38 PM    System    -110022    /DEF/F6/I1/NLS/EN_US.TXT
Thu 2022/03/31 09:53:41 PM    System    -7066    ID 00A5 :err=0, tag='id', num=22, nest=6, offse
Thu 2022/03/31 09:53:53 PM    System    -7123    ID 0037 :err=0, tag='control', num=6, nest=4, o
Thu 2022/03/31 09:54:04 PM    System    -7066    ID 0171 :err=0, tag='id', num=22, nest=6, offse
Thu 2022/03/31 09:54:04 PM    System    -7066    ID 0172 :err=0, tag='id', num=22, nest=6, offse
Thu 2022/03/31 09:54:04 PM    System    -7066    ID 0173 :err=0, tag='id', num=22, nest=7, offse
Thu 2022/03/31 09:54:04 PM    System    -7066    ID 0187 :err=0, tag='id', num=22, nest=6, offse
Thu 2022/03/31 09:54:05 PM    System    -7066    ID 00A1 :err=0, tag='id', num=22, nest=5, offse
Thu 2022/03/31 09:54:05 PM    System    -7066    ID 0191 :err=0, tag='id', num=22, nest=6, offse
Thu 2022/03/31 09:54:05 PM    System    -7066    ID 00A3 :err=0, tag='id', num=22, nest=5, offse
Thu 2022/03/31 09:54:05 PM    System    -7066    ID 01A4 :err=0, tag='id', num=22, nest=5, offse
Thu 2022/03/31 09:54:05 PM    System    -7066    ID 01B6 :err=0, tag='id', num=22, nest=5, offse
Thu 2022/03/31 09:54:05 PM    System    -7066    ID 01B7 :err=0, tag='id', num=22, nest=5, offse
Thu 2022/03/31 09:54:05 PM    System    -7066    ID 01CF :err=0, tag='id', num=22, nest=5, offse
Thu 2022/03/31 09:54:06 PM    System    -7066    ID 01DA :err=0, tag='id', num=22, nest=5, offse
Thu 2022/03/31 09:54:06 PM    System    -7066    ID 01DF :err=0, tag='id', num=22, nest=5, offse
Thu 2022/03/31 09:54:06 PM    System    -7066    ID 020F :err=0, tag='id', num=22, nest=5, offse
Thu 2022/03/31 09:54:06 PM    System    -7066    ID 0235 :err=0, tag='id', num=22, nest=5, offse
Thu 2022/03/31 09:54:15 PM    System    -110022    /CONF/UZWNDKEY.TXT
Thu 2022/03/31 09:54:15 PM    System    -110012    /CONF/UZWNDKEY.TXT
Thu 2022/03/31 09:54:16 PM    System    -170001    [Network] Established
Thu 2022/03/31 09:54:16 PM    System    -60006    n/a
Thu 2022/03/31 09:54:25 PM    System    -251001    RX-U 010B000A03000102
Thu 2022/03/31 09:57:50 PM    System    -140008    ISY:503
Thu 2022/03/31 09:57:51 PM    System    -140008    ISY:503
Thu 2022/03/31 09:57:52 PM    System    -140008    ISY:503
Thu 2022/03/31 09:57:53 PM    System    -140008    ISY:503
Thu 2022/03/31 09:57:54 PM    System    -140008    ISY:503
Thu 2022/03/31 09:57:55 PM    System    -140008    ISY:503
Thu 2022/03/31 09:57:56 PM    System    -140008    ISY:503
Thu 2022/03/31 09:57:57 PM    System    -140008    ISY:503
Thu 2022/03/31 09:57:58 PM    System    -140008    ISY:503
Thu 2022/03/31 09:57:59 PM    System    -140008    ISY:503
Thu 2022/03/31 09:58:00 PM    System    -140008    ISY:503
Thu 2022/03/31 09:58:01 PM    System    -140008    ISY:503
Thu 2022/03/31 09:58:02 PM    System    -140008    ISY:503
Thu 2022/03/31 09:58:03 PM    System    -140008    ISY:503
Thu 2022/03/31 09:58:52 PM    System    -50001    -11
Thu 2022/03/31 09:58:54 PM    System    -50001    -6
Thu 2022/03/31 09:58:58 PM    System    -50001    -11
Thu 2022/03/31 09:59:01 PM    System    -50001    -11
Thu 2022/03/31 09:59:03 PM    System    -50001    -11
Thu 2022/03/31 09:59:10 PM    System    -50001    -11
Thu 2022/03/31 09:59:15 PM    System    -50001    -6
Thu 2022/03/31 10:03:03 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:04 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:05 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:06 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:07 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:08 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:09 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:10 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:11 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:12 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:13 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:14 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:15 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:16 PM    System    -140008    ISY:503
Thu 2022/03/31 10:03:27 PM    System    -50001    -11
Thu 2022/03/31 10:04:13 PM    System    -110020    /TMP/19/insteon.img
Thu 2022/03/31 10:39:35 PM    System    -50001    -11
Thu 2022/03/31 11:08:34 PM    System    -50001    -6
Thu 2022/03/31 11:18:34 PM    System    -50001    -6
Thu 2022/03/31 11:20:18 PM    System    -110020    /TMP/19/insteon.img
Thu 2022/03/31 11:55:05 PM    System    -50001    -11
Thu 2022/03/31 11:55:07 PM    System    -50001    -11
Thu 2022/03/31 11:58:34 PM    System    -50001    -11
Fri 2022/04/01 12:05:55 AM    System    -110020    /TMP/19/insteon.img
Fri 2022/04/01 12:08:34 AM    System    -50001    -11
Fri 2022/04/01 12:15:24 AM    System    -10011    n/a
Edited by oskrypuch
