Unable to send notifications
Hello, I have just upgraded my Polisy to ISY 5.4.3. I wrote my first program that included a command to send a text and email notification. When I tested this by executing the "Run Then" command I did not get any notifications. If I go to the Configurations - Setting/Groups and run a Test, I get a correct test notification on both Text and Email.
Here is the program:
If - Attic Leak Sensor / ZW002 Water Detected 1 Status is On
Then - Send Notification 'Tom Text and Email' Content 'Attic Leak Sensor'
I Just found the issue...
Under the "My Programs" folder I had an erroneous "If" condition. I deleted that condition and.... Voila!! It worked just fine. Sorry for the false alarm.
A tip for all....
Right click any program or folder and set "detailed" Status Icons.  That way you can see at a glance if there is a folder condition above your program that is resolving to false.
@Michel Kohanim  Suggestion:  can we just eliminate this choice and force "detailed" for all?  Detailed is much more informative and I don't know why anyone that knows of this choice would choose either Folders Only or Simple.
6 hours ago, MrBill said:
A tip for all....
Appears as a hang-over from a testing phase that is not required anymore.
I second that. New users wondering WTF are others talking about...changing icons?
