3.1.4 error on startup
EDIT: This isn't a fatal error!  The Node server is running as designed, as far as I can tell.
I've deleted the PG2 version, and installed the PG3 version, but it errors on startup:
2022-04-18 07:18:46,691 MainThread udi_interface.interface INFO     interface:addNode: Adding node WirelessTagsController(wtcontroller) [None]
2022-04-18 07:18:46,694 MainThread udi_interface.interface INFO     interface:setController: Using node "wtcontroller", driver "ST" for connection status.
2022-04-18 07:18:46,884 Thread-6   udi_interface      ERROR    Controller:handler_nsdata: NSDATA is a string?  Are you running a local copy? data=undefined
Thanks for whatever insight you can give, or, I can just ignore it...
Edited by Bumbershoot
