IoP (ISY on Polisy) - come on in, the water is just fine!
Well, just to relate my positive experience.
When PGC went down, I needed to get my Polyglot back up, so made the step I had been deferring for a bit, and bought a Polisy. I was initially just going to use it for Polyglot, but then when I started developing some issues with my current ISY994 and the need to include Z-Wave, decided to do the full migration.
I have a large Insteon setup with a working serial PLM (and just started adding Z-Wave, 'cause I have to for the future), and was serving some weather services. I just bought a new Tempest, and wanted to get that up and running too.
Did a lot of reading, and punched around the various setup screens, and here I am with my entire Insteon setup moved over, the weather services set up, Tempest feeding it, and I'm delighted.
Still have to move my ISY Portal license to the Polisy (using the 1mo free one as per the directions), and then will need to repoint my UD app, it appears that should work without the need to set it up again, but we'll see.
In any case, one happy customer.
The Polisy certainly seems a lot more zippy. The ISY994 was no slouch, but you can't beat faster, more up to date hardware. And good timing, that my Z-Wave leap will now be solely hosted on the Polisy, no need for later migration.
* Orest
Edited by oskrypuch
Yep, even the Portal migration went just fine, and the UD app favorites ported across 100% - that saves a lot of time!
* Orest
