default IR codes
I previosly tried learning some IR codes trough my Isy-99IR, and found they are quite noisy. I wanted to try the default IR codes, but cant seem to find the "import IR codes" button referanced in the manual (supposed to be top of the screen. Did something change when I selected to learn codes, and this is no longer viable? Or do I have to reset something?
helipal, at the minimum, I suggest upgrading to 2.7.7 ... if you feel brave, then upgrade to 2.7.9 and you should see the button in Configuration/IR tab.
