isy994i 5.0.16b - homebridge v1.4.1 - pradeepmouli plugin - error Error initializing ISY: {}
Hello.  I'm trying out Homebridge with the pradeepmouli plugin.  When I restart Homebridge, the logs say Error initializing ISY: {}.
Does my isy994i have to have internet access enabled ?  I've tried enabling it anyways and it fails to enable.
The Homebridge log file says:
[isy-nodejs] Error initializing ISY: {}
[2022-05-01, 2:46:29 p.m.] [isy-nodejs] Connecting to: ws://192.168.1.103/rest/subscribe
[2022-05-01, 2:46:29 p.m.] [ISY] Accessories to configure: 0
[2022-05-01, 2:46:29 p.m.] [ISY] ISY has 0 devices and 0 scenes
Does anyone have any suggestions?
No internet Enabled is out of date... it actually enables UPnP... which shouldn't be enabled.  It fails because your router rejects UPnP for security reasons.
I can't tell you anything about the homebridge plugin but this should work "[isy-nodejs] Connecting to: ws://192.168.1.103/rest/subscribe" assuming that is the correct IP address for your ISY, and the two devices are on the same subnet and can talk to each other.
Thanks MrBill.  I made a rooky mistake and had the ip address wrong.  (oh noooooooo mrbill)
Now that it finds my isy994i and lists the devices in the homebridge log, how do I get them to show up as an accessories?
Again I don't have that plugin, but open the Home app and click the + in the top right, then select Add Accessory, then click the more options link and I think they will be found.
