Insteon 6 Button as ALL OFF in ISY Programming
2 hours ago, KHouse said:
What do you mean by this?
The main basement lights are connected to the ON/OFF buttons on the 6 button switch, so if you press ON, the main basement lights are on and the ON button is backlit.
If you press off (now that my programming is done)...all/any of the basement lights that are on will turn off...so it's an ALL OFF essentially.
I guess the question is, how to make the ON button light turn on (backlit) when any of the lights are on?
You can't do that is what I mean unless you're ok with the main light turning on as well
In different words, since your main basement lights are physically powered by the six-button keypad, and time that you turn on the keypad main (on/off) button, the connected load will also turn on.  I was wrong to suggest that it could the on button could be lit without the main basement lights being on.
