Ross Posted May 11, 2022 Posted May 11, 2022 I have some I/O Lincs scattered around the house (doorbell, chicken coop open/close, garage door). My (possibly faulty) understanding is that the I/O Lincs are powerline only - not RF. I also understand that the Hub makes for a good repeater - does that include powerline? I never had one. I guess the question is: would a Hub or Access Point help with making sure my I/O Lincs (and possibly other Insteon devices) always get the signal? The hubs are going for <$100 and I might scatter a couple in far away places. I wouldn't necessarily use them for anything else. Thank you, Ross
lilyoyo1 Posted May 11, 2022 Posted May 11, 2022 2 hours ago, Ross said: I have some I/O Lincs scattered around the house (doorbell, chicken coop open/close, garage door). My (possibly faulty) understanding is that the I/O Lincs are powerline only - not RF. I also understand that the Hub makes for a good repeater - does that include powerline? I never had one. I guess the question is: would a Hub or Access Point help with making sure my I/O Lincs (and possibly other Insteon devices) always get the signal? The hubs are going for <$100 and I might scatter a couple in far away places. I wouldn't necessarily use them for anything else. Thank you, Ross Any dual band device would help. If you're ok with a big hub scattered throughout you can use that. It does have a stronger radio than other devices but it's also doesn't blend in as well 1
Brian H Posted May 11, 2022 Posted May 11, 2022 The I/OLinc is a power line only module as you suspected. I have a spare 2457D2 LampLinc being used as a signal area enhancing module. Was a rebuilt PLM. The Range Extender they use to sell was actually a newer Dual Band LampLinc with the dimming parts not installed. One thing to look at with the Access Points. The revision 2 hardware is built on the base 2413 main board and had the same power supply issues as our PLM. The revision 1 version where using the older 2412 main board with a added daughter board in them. In my tests the revision 1 units has a slightly better range. 1
