Migrating PLM from 2413S to 2448A7
Do I need to factory reset the dongle or can I just plug it in and "restore PLM" from the Polisy? The dongle was bought used.
If I need to factory reset it, how would you do this? I'm not finding any manuals online. Only a quickstart guide which does not give instructions to factory reset.
From what I have seen. In my ISY994i. Restore Modem (PLM) does a software reset command of the attached PLM. Then writes the links into it and changes the old PLM 6 digit ID to the new 6 digit ID in all the modules.
I found a handy slick little Windows program when I was setting up Home Assistant called Linknet that I used to reset my Insteon USB stick.  You can use it to look at current links if any in the stick or PLM and there are other features as well.
https://insteonsoftware.com
Edited by mmb
