Leak Sensors Summary & Variables
Hi All,
Yesterday around 1:30pm, I updated Polisy to 5.4.4 in addition to updating the BIOS. All went well without any issues. All programs executed as scheduled, but noticed 2 changes on the Leak Sensor Summary page (see attached) that may or may not mean anything. As some of you know, I am not a programmer, but I am trying to learn from reading the ISY wiki, forum posts and anything else I can get my hands on to better understand since migrating from the Insteon Hub to IoP.
When the Leak Sensor program was first setup, the Heartbeat "status" always showed "True" followed by "Timeout" and "Wet" showing False. Since yesterday's update, the status of the Heartbeat program shows False. I am not sure this makes any difference since the Heartbeat program checked in within 24 hours as shown on my attached spreadsheet.
If all looks good, then I am trying to understand the difference in the True/False status column.
Thanks and have a great Memorial Day weekend!
Gary
Leak Sensor Summary.xlsx
All looks good. If you want to test one off the sensors just to make sure it's working, you can place it on a wet paper towel.
If the WET status in the admin console changes to ON then it's working, when you press the set button the WET status should show OFF
anytime you reboot the ISY heartbeat using your programs will probably be false for 24 hours... i didn't go thru the logic of your programs to doublecheck, but that's my guess.  Wait more than 24 hours from reboot and then check.
