getting ready to migrate from ISY IoP
I am currently running Poilsy on PLM 2413s v92 and Isy on v9E is there any reason to swap PLMs before or after migration, does it make a difference, I wiil continue to use both ISYs untill I feel comfortable that everything is OK.
Thoughts, ideas, warnings?
Probably won't do this till next week end.
Edited by CopyRon
You can have issues running both depending on system since all devices communicate with each other regardless of where the signal comes from. This can lead to collisions and delays since you'll have 2 separate controllers. With that said, if you know what you're doing and plan accordingly, it's possible with minimal interference.
Since you're running both, no it doesn't matter in regards to PLM. Personally, I'd use the PLM with polisy that i plan on using long term just to avoid having to do another swap later.
