Trouble linking Remotelinc, Lamplinc and ISY-26
deeeveeeg
I've been X-10ing for a number of years and discovered ISY-26 online and immediately began investigating. Just picked one up last week along with the INSTEON RemoteLinc Starter Kit and an INSTEON SwitchLinc Dimmer.
So far I have only been able to get the switchlinc dimmer and one of the lamplincs to climb aboard the admin console. I just finally got the remotelinc to link to the console. Are the access points suppose to be added to the console as well?
When I try to add the other lamplinc via console - Link Management - New Insteon Device, Initializing System gets to 43 or 44 % and then an error window pops up "Request Failed".
I've tried moving access points, removing the happy lamplinc and putting the unhappy lamplinc in the same outlet then retry linking. I've either got a faulty one or I'm missing some simple setting.
As far as the remotelinc, it seems to work just fine outside of the admin console, but can't get it to show up in the console. BTW, what or where is "button 1" referred to in the message dialog after clicking Link a RemoteLinc in the console? Fixed this. Remotelinc is now linked and visible in console. So "button 1" is scene A On button?
Now that the above (green) is fixed, I'll try linking the lamplinc to the remotelinc outside of console then relinking remotelinc to console.
I appreciate Michel's quick response and welcome this weekend and comments and assistance (just in my reading) by fellow ISY users throughout the forum. Despite some initial issues and frustration, I'm very happy with UDI and the ISY-26 as well as being able to graduate from X-10.
Thanks in advance for any help.
Steven
Link to comment
This should be easy.
Use a factory reset on the bad LampLinc.
Or
Enter the Insteon ID in the ISY and after it is linked use Restore Device on the little puppy.
Or do both, in that order.
Otherwise you might have a soiled LampLinc.
Don't do that :roll:
Yes, 1-3 across the top, 4-6 on the bottom.
Even when using the ISY the RemoteLinc must be set in linking mode before you create new links to it. After the links are created the RemoteLinc is not involved when changing levels and rates.
Rand
Link to comment
Thanks Rand.
Almost nothing worthwhile is ever easy!
I've done a f reset and tried entering the insteon address which I'm guessing is the same as the ID. Reset seemed to work but adding the lamplinc by typing it's address in ISY fails every time.
Remotelinc shows all 6 addresses in ISY, but the one the bad lamplinc is connected to fails anything tried with it in ISY.
I Should unlink that lamplinc from the remotelinc and then do the factory restore on the lamplinc, correct? Then should I try to add it to ISY from the menu or button OR should I link it to remotelinc with remotelinc buttons? I would think it doesn't matter, but figured I might as well ask.
I'll be back later this afternoon to try the repeat.
I appreciate your help Rand.
Link to comment
Tried all of the suggestions. Bad lamplinc will factory reset fine and will connect to remotelinc fine and work with remotelinc fine but doesn't want to play with admin console. Here is the error when trying to add it to a scene:
Device Communications Error
Cannot communicate with RL-B1 0A.14.37.1 (A 14 37 1). Please check connections.
I notice it drops the leading 0 from LL's address at the end. Seems like someone wrote about leading zeos, but my other LL starts with the same 0A and it works fine.
Any other suggestions? Seems like if I tell Smarthome that it works fine outside of ISY-26 then they won't see it as a bad device.
I was just reading Q&A and I guess I'll try moving the LL around to a few different locations. If that fails I'll put it back where it was and move the PLM and ISY-26 around. I've done this to a small extent, but not exuastiively. UGGHHH!
Steven
Link to comment
Steven,
I am so very sorry to hear about all these issues you've been experiencing with your ISY/devices. I am available today (Sunday); if you wish we can have a call to go through the issues. On LL, make sure you have a lamp actually plugged into it. Whenever you are ready, siimply send an email to tech@universal-devices.com and I'll call you.
Again, accept my apologies for your troubles,
Steven
Link to comment
Steven
Steve,
Did you ever get this to work? I'm having similar problems with a SwitchLinc Dimmer. I replaced one last night, but I'm having problems with the new SwitchLinc as well.
Kelly
Link to comment
Kelly,
Steven had a defect LL; we sent him a new one to test and that was the case. When we receive the old one, we are going to figure out the root cause.
Steve,
Kelly
Link to comment
      36.9k
      370.6k
