Text Message to Spectrum Cell Phone
Does anyone know if there is the option to send a text message to someone that that has spectrum cellular.  I could not find spectrum in the drop down and wondering if there is someone that partners with them for text messages.
If there is not an option, I will see if I can get them to sign up for push messages.
Thank you
Try xxx-xxx-xxxx@vtext.com
I found some info online saying they may use Verizon's towers.
@Athlon
Thank you so much for your research.  I should have done that first before posting but to be honest, i did not think of doing that.  I am in the process of testing with the individual and will respond back with the results.
@hart2hart  I went to pushover because the reliability was so bad with critical things in my home.  However, my problem is I am working with a non-technical person some miles away.  She has been using ATT and that was working for her.  I am hoping we can get by with Athlon's suggestion because of the difficulty in getting her changed to something else.
@Athlon  Just completed a successful test with this format
xxx-xxx-xxxx@vtext.com.
Very much appreciate your help.  I was not looking forward to going the pushover route even though in the long run that would be better.
21 minutes ago, hart2hart said:
All of these options have become very unreliable in the past year with cellular company’s policy updates.
Our cell phones are with ATT. I've had a program for sometime that texts me when a garage door is left open for more than 30 minutes. It's been working fine.
His MMV with Spectrum, of course. Should be easy to test it.
