Isy on Polisy and Network Rescources
Moved to ISY on Polisy, last remaining item to figure out in using network resouces to directly control webcontrol Cai outputs.
Here is what i have used in the past with ISY994 (first Picture).   Not working  after migration in my programs and the test button on the bottom of the summary page is grayied out (second picture).   I have tried completely recreating the entry but still no go.   Re-enter autorization  to check, this did not work.
Eric
Just a wild guess but maybe the networking module did not update correctly in the transition to IoP. This would require a ticket with UD to fix.
What does help, about show in AC?
Did you try going to your programs that use the resource, then refreshing the network resources line, then re-save the program?  (browse to the Network Resources tab first before looking at programs)
I have tried the following:
1.  tried to refresh each network resource line and resaved, no good.
2. tried to delete and then reenter the network resource information for one of the lines. No good.
Still working on it
This is used in communication between CAI WEB control  and ISY
Wed Control to ISY works fine ( using Web Control Program)
ISY to Web Control  not working after change (using isy nework resource)
I will fiigure it out or us Web Control in Nodelink
JTsao
Thanks that got it.  Had to refresh in the network resource for each one and then in the programs  reload the lines with the TTL calls.  Now working.
You already solved your issue, but just to comment, the test button only works after something was saved using the save button to its left.  You must also select a row to test first.
Edited by MrBill
