MagicHome on polisy installs on ployglot then removes it self
I have just move over to Polisy and everything is working good I have serval different node servers up and running. But when I install MagicHome it comes up with not online and after a while it disappears from the list of servers.
6/25/2022, 08:01:36 [pg3] info: [00:0d:b9:5e:df:b4_6] :: Creating Node server 'MagicHome' 6/25/2022, 08:01:36 [pg3] debug: Add: {"uuid":"00:0d:b9:5e:df:b4","name":"MagicHome","nsid":"7b031b27-643b-4678-ae54-cc63c346436b","profileNum":"6","version":"1.0.2","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:df:b4_6","type":"python3","executable":"magichome.py","devMode":0,"branch":"null","url":"https://pg3store.isy.io/v2/node servers/production/udi-magic-poly.zip","shortPoll":30,"longPoll":300,"logLevel":"INFO","nsInfoPoll":0,"discover":1,"oauth":false,"store":"Production"} 6/25/2022, 08:01:36 [pg3] info: Adding customparams entries to custom database 6/25/2022, 08:01:36 [pg3] info: Adding nsdata, oauth entries to custom database 6/25/2022, 08:01:36 [pg3] info: [00:0d:b9:5e:df:b4_6] Set nsdata 6/25/2022, 08:01:36 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_6] {"custom":{"nsdata":"null"}} 6/25/2022, 08:01:36 [pg3] info: [00:0d:b9:5e:df:b4_6] Set oauth 6/25/2022, 08:01:36 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_6] {"custom":{"oauth":"null"}} 6/25/2022, 08:01:36 [pg3] debug: Deploy MagicHome in /var/polyglot/pg3/ns/00:0d:b9:5e:df:b4_6 6/25/2022, 08:01:36 [pg3] warn: [00:0d:b9:5e:df:b4-6] :: Node server folder exists, removing... /var/polyglot/pg3/ns/00:0d:b9:5e:df:b4_6 6/25/2022, 08:01:36 [pg3] info: [00:0d:b9:5e:df:b4_6] :: Downloading and unpacking https://pg3store.isy.io/v2/node servers/production/udi-magic-poly.zip into /var/polyglot/pg3/ns/00:0d:b9:5e:df:b4_6 6/25/2022, 08:01:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_6 to broker pg3_broker 6/25/2022, 08:01:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_6 to broker pg3_broker 6/25/2022, 08:01:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2 to broker pg3_broker 6/25/2022, 08:01:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2 to broker pg3_broker 6/25/2022, 08:01:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2 to broker pg3_broker 6/25/2022, 08:01:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2 to broker pg3_broker 6/25/2022, 08:01:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2 to broker pg3_broker 6/25/2022, 08:01:37 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}} 6/25/2022, 08:01:37 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:01:39 [pg3] error: unhandledRejection REPORT THIS!: [object Promise], reason: Error: Request failed with status code 404 6/25/2022, 08:01:49 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_Gh9JV has published message on udi/pg3/frontend/isy/n2uns to broker pg3_broker 6/25/2022, 08:01:49 [pg3] debug: MQTT Results: [frontend/isy/n2uns] :: {"getNodeServers":[{"id":"b7d3fb4c-5e17-4b96-afa0-3f998642311f","uuid":"00:0d:b9:5e:df:b4","token":"m5t7)s?WV4hk8STp","name":"ISY Portal","nsid":"","expires":0,"nickname":null,"profileNum":1,"timeAdded":1656115819820,"timeStarted":null,"timeModified":1656115819820,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"1f2fdf05-d20b-4bb9-a2a9-0b5f144c6911","uuid":"00:0d:b9:5e:df:b4","token":"wc2vNu6ohJH8zkHe","name":"WeatherBit","nsid":"5eb66567-6a98-49e9-bd3c-b954d24ee26a","expires":0,"nickname":null,"profileNum":3,"timeAdded":1656115765198,"timeStarted":1656115774975,"timeModified":1656117940167,"version":"2.0.5","branch":"","url":"http://pg3store.isy.io/v2/node servers/production/udi-weatherbit-poly.zip","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:df:b4_3","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"weatherbit.py","shortPoll":300,"longPoll":600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":4,"notices":{}},{"id":"cb2f4d46-beca-4517-be01-df688a2ffd68","uuid":"00:0d:b9:5e:df:b4","token":"3f&X0q&hB+TgKzT6","name":"AmbientWeather","nsid":"6f402c66-a450-4f39-a254-1cd998ce5c49","expires":0,"nickname":null,"profileNum":4,"timeAdded":1656118034543,"timeStarted":1656118151742,"timeModified":1656118157659,"version":"2.0.6","branch":"","url":"https://pg3store.isy.io/v2/node servers/production/udi-ambient-poly.zip","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:df:b4_4","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"ambient-poly.py","shortPoll":600,"longPoll":1200,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":3,"notices":{}},{"id":"7997a2e5-e12b-4a00-8a77-4f1486e02e6c","uuid":"00:0d:b9:5e:df:b4","token":"B*oKQAI1B)d*B=Rh","name":"LiFX","nsid":"a2989a18-4edc-46b7-b9bc-92bff80cef5c","expires":0,"nickname":null,"profileNum":5,"timeAdded":1656155355875,"timeStarted":1656155403645,"timeModified":1656155617179,"version":"2.1.26","branch":"master","url":"https://github.com/exking/udi-lifx-pg3.git","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:df:b4_5","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"lifx-poly.py","shortPoll":120,"longPoll":600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":1,"notices":{}},{"id":"8ac4157a-fadf-4570-a2ee-bb12d2692195","uuid":"00:0d:b9:5e:df:b4","token":"tHsTrxd7o0AE1%II","name":"MagicHome","nsid":"7b031b27-643b-4678-ae54-cc63c346436b","expires":0,"nickname":null,"profileNum":6,"timeAdded":1656158496135,"timeStarted":null,"timeModified":1656158496135,"version":"1.0.2","branch":"null","url":"https://pg3store.isy.io/v2/node servers/production/udi-magic-poly.zip","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:df:b4_6","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"magichome.py","shortPoll":30,"longPoll":300,"nsInfoPoll":0,"discover":1,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":0,"notices":{}}]} 6/25/2022, 08:01:49 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2 to broker pg3_broker 6/25/2022, 08:01:53 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}} 6/25/2022, 08:01:53 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:02:03 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}} 6/25/2022, 08:02:03 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:02:23 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}} 6/25/2022, 08:02:23 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:02:33 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}} 6/25/2022, 08:02:33 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:02:53 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}} 6/25/2022, 08:02:53 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:02:59 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"longPoll":{}} 6/25/2022, 08:02:59 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:03:03 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}} 6/25/2022, 08:03:03 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:03:23 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}} 6/25/2022, 08:03:23 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:03:24 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_Gh9JV has published message on udi/pg3/frontend/ns/n2uns to broker pg3_broker 6/25/2022, 08:03:24 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_Gh9JV has published message on udi/pg3/frontend/ns/n2uns to broker pg3_broker 6/25/2022, 08:03:24 [pg3] debug: MQTT Results: [frontend/ns/n2uns] :: {"getNs":{"id":"8ac4157a-fadf-4570-a2ee-bb12d2692195","uuid":"00:0d:b9:5e:df:b4","token":"tHsTrxd7o0AE1%II","name":"MagicHome","nsid":"7b031b27-643b-4678-ae54-cc63c346436b","expires":0,"nickname":null,"profileNum":6,"timeAdded":1656158496135,"timeStarted":null,"timeModified":1656158496135,"version":"1.0.2","branch":"null","url":"https://pg3store.isy.io/v2/node servers/production/udi-magic-poly.zip","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:df:b4_6","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"magichome.py","shortPoll":30,"longPoll":300,"nsInfoPoll":0,"discover":1,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"notices":{},"nodes":[]}} 6/25/2022, 08:03:24 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2 to broker pg3_broker 6/25/2022, 08:03:24 [pg3] info: [00:0d:b9:5e:df:b4_6] Retrieved customparams 6/25/2022, 08:03:24 [pg3] info: [00:0d:b9:5e:df:b4_6] Retrieved oauth 6/25/2022, 08:03:24 [pg3] debug: MQTT Results: [frontend/ns/n2uns] :: {"getCustom":[{"id":"9f7f026e-fa43-4272-9be3-94afc4968871","uuid":"00:0d:b9:5e:df:b4","profileNum":6,"key":"customparams","value":"null","dbVersion":1},{"id":"3485502d-b4a1-4fbe-b83a-c77cd626384a","uuid":"00:0d:b9:5e:df:b4","profileNum":6,"key":"oauth","value":"null","dbVersion":1}]} 6/25/2022, 08:03:24 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2 to broker pg3_broker 6/25/2022, 08:03:27 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_Gh9JV has published message on udi/pg3/frontend/ns/n2uns to broker pg3_broker 6/25/2022, 08:03:27 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_6] {"discover":{}} 6/25/2022, 08:03:27 [pg3] debug: MQTT Results: [frontend/ns/n2uns] :: {} 6/25/2022, 08:03:27 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_6 to broker pg3_broker 6/25/2022, 08:03:27 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2 to broker pg3_broker 6/25/2022, 08:03:33 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}} 6/25/2022, 08:03:33 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:03:37 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"longPoll":{}} 6/25/2022, 08:03:37 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:03:37 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}} 6/25/2022, 08:03:37 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker 6/25/2022, 08:03:38 [pg3] debug: Client pg3frontend_Gh9JV unsubscribed from udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2/log/00:0d:b9:5e:df:b4_6 6/25/2022, 08:03:38 [pg3] debug: Stopping log stream for pg3frontend_Gh9JV 6/25/2022, 08:03:38 [pg3] debug: Sending logfile to frontend :: /var/polyglot/pg3/logs/pg3-current.log
6/25/2022, 08:03:38 [pg3] debug: Starting log stream for pg3frontend_Gh9JV :: /var/polyglot/pg3/logs/pg3-current.log
6/25/2022, 08:03:53 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}}
6/25/2022, 08:03:53 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker
6/25/2022, 08:04:03 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}}
6/25/2022, 08:04:03 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker
6/25/2022, 08:04:20 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"longPoll":{}}
6/25/2022, 08:04:20 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker
6/25/2022, 08:04:23 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}}
6/25/2022, 08:04:23 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker
6/25/2022, 08:04:33 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}}
6/25/2022, 08:04:33 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker
6/25/2022, 08:04:38 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_3] {"shortPoll":{}}
6/25/2022, 08:04:38 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_3 to broker pg3_broker
6/25/2022, 08:04:38 [pg3] debug: [MESSAGE_PUBLISHED] Client 00:0d:b9:5e:df:b4_3 has published message on udi/pg3/ns/status/00:0d:b9:5e:df:b4_3 to broker pg3_broker
6/25/2022, 08:04:38 [pg3] debug: Scheduling http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/CLITEMP/66.2/17 to group statusGroup
6/25/2022, 08:04:38 [pg3] debug: Created Status Queue for Node server 3
6/25/2022, 08:04:38 [pg3] debug: Scheduling http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/CLIHUM/63/22 to group statusGroup
6/25/2022, 08:04:38 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:df:b4] :: [200] :: 26.318352ms - http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/CLITEMP/66.2/17
6/25/2022, 08:04:38 [pg3] debug: MQTT Results: [ns/status/00:0d:b9:5e:df:b4,3] :: {"set":[{"address":"controller","driver":"CLITEMP","value":"66.2","uom":17}]}
6/25/2022, 08:04:38 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_3] {"set":[{"address":"controller","driver":"CLITEMP","value":"66.2","uom":17}]}
6/25/2022, 08:04:38 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2 to broker pg3_broker
6/25/2022, 08:04:38 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:df:b4] :: [200] :: 8.951494ms - http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/CLIHUM/63/22
6/25/2022, 08:04:38 [pg3] debug: Scheduling http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/BARPRES/995/117 to group statusGroup
6/25/2022, 08:04:38 [pg3] debug: Scheduling http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/WINDDIR/160/76 to group statusGroup
6/25/2022, 08:04:38 [pg3] debug: MQTT Results: [ns/status/00:0d:b9:5e:df:b4,3] :: {"set":[{"address":"controller","driver":"CLIHUM","value":"63","uom":22}]}
6/25/2022, 08:04:38 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_3] {"set":[{"address":"controller","driver":"CLIHUM","value":"63","uom":22}]}
6/25/2022, 08:04:38 [pg3] debug: Scheduling http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/GV2/65.6/17 to group statusGroup
6/25/2022, 08:04:38 [pg3] debug: Scheduling http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/SOLRAD/346.2/74 to group statusGroup
6/25/2022, 08:04:38 [pg3] debug: Scheduling http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/GV16/2.48044/71 to group statusGroup
6/25/2022, 08:04:38 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:df:b4] :: [200] :: 7.542652ms - http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/BARPRES/995/117
6/25/2022, 08:04:38 [pg3] debug: MQTT Results: [ns/status/00:0d:b9:5e:df:b4,3] :: {"set":[{"address":"controller","driver":"BARPRES","value":"995","uom":117}]}
6/25/2022, 08:04:38 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_3] {"set":[{"address":"controller","driver":"BARPRES","value":"995","uom":117}]}
6/25/2022, 08:04:38 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:df:b4] :: [200] :: 4.975306ms - http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/WINDDIR/160/76
6/25/2022, 08:04:38 [pg3] debug: MQTT Results: [ns/status/00:0d:b9:5e:df:b4,3] :: {"set":[{"address":"controller","driver":"WINDDIR","value":"160","uom":76}]}
6/25/2022, 08:04:38 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_3] {"set":[{"address":"controller","driver":"WINDDIR","value":"160","uom":76}]}
6/25/2022, 08:04:38 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:df:b4] :: [200] :: 11.557322ms - http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/GV2/65.6/17
6/25/2022, 08:04:38 [pg3] debug: MQTT Results: [ns/status/00:0d:b9:5e:df:b4,3] :: {"set":[{"address":"controller","driver":"GV2","value":"65.6","uom":17}]}
6/25/2022, 08:04:38 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_3] {"set":[{"address":"controller","driver":"GV2","value":"65.6","uom":17}]}
6/25/2022, 08:04:39 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_3 to broker pg3_broker
6/25/2022, 08:04:39 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:df:b4] :: [200] :: 5.471859ms - http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/SOLRAD/346.2/74
6/25/2022, 08:04:39 [pg3] debug: MQTT Results: [ns/status/00:0d:b9:5e:df:b4,3] :: {"set":[{"address":"controller","driver":"SOLRAD","value":"346.2","uom":74}]}
6/25/2022, 08:04:39 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_3] {"set":[{"address":"controller","driver":"SOLRAD","value":"346.2","uom":74}]}
6/25/2022, 08:04:39 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/aae4228c-b3f4-4f0b-bbba-99b519310de2 to broker pg3_broker
6/25/2022, 08:04:39 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:df:b4] :: [200] :: 5.65676ms - http://192.168.12.167:8080/rest/ns/3/nodes/n003_controller/report/status/GV16/2.48044/71
6/25/2022, 08:04:39 [pg3] debug: MQTT Results: [ns/status/00:0d:b9:5e:df:b4,3] :: {"set":[{"address":"controller","driver":"GV16","value":"2.48044","uom":71}]}
6/25/2022, 08:04:39 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_3] {"set":[{"address":"controller","driver":"GV16","value":"2.48044","uom":71}]}
6/25/2022, 08:04:53 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}}
6/25/2022, 08:04:53 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker
6/25/2022, 08:05:03 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5] {"shortPoll":{}}
6/25/2022, 08:05:03 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:df:b4_5 to broker pg3_broker
6/25/2022, 08:05:22 [pg3] debug: Scheduling http://192.168.12.167:8080/rest/profiles/ns/0/connection to group system
6/25/2022, 08:05:22 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:df:b4] :: [200] :: 47.710548ms - http://192.168.12.167:8080/rest/profiles/ns/0/connection
6/25/2022, 08:05:22 [pg3] warn: [00:0d:b9:5e:df:b4_6] ISY does not have this Node server. Removing from PG3.
any Ideas of what I am doing wrong?
thanks Kevin
It is being removed because it never gets installed on the ISY.  It's failing to install because the install package is missing.
I've uploaded the install package so it should install now.
I've been working on major updates to the packaging and install process and apparently, I broke something and it never uploaded the package when I added it to the store.
Thanks it installed no problem. I am haven't trouble setting any levels. It turns them on and off but I cant get any levels to change.
022-06-25 13:51:51,345 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e03f1d6 :: GV5 to 0 UOM 25 2022-06-25 13:54:24,969 Thread-14 udi_interface ERROR rgbled:setLevels: * * * Unrecognised bulb type:51 2022-06-25 13:55:52,955 Thread-581 udi_interface ERROR rgbled:setLevels: * * * Unrecognised bulb type:51 2022-06-25 13:55:52,968 Thread-581 udi_interface ERROR rgbled:setLevels: * * * Unrecognised bulb type:51 2022-06-25 13:55:53,107 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: ST to 86 UOM 51 2022-06-25 13:55:53,205 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: GV5 to 1 UOM 25 2022-06-25 13:56:00,668 Thread-581 udi_interface ERROR rgbled:setLevels: * * * Unrecognised bulb type:51 2022-06-25 13:56:00,681 Thread-581 udi_interface ERROR rgbled:setLevels: * * * Unrecognised bulb type:51 2022-06-25 13:56:29,912 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: ST to 86 UOM 51 2022-06-25 13:56:30,068 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: GV1 to 220 UOM 56 2022-06-25 13:56:30,335 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: GV2 to 234 UOM 56 2022-06-25 13:56:30,377 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: GV3 to 255 UOM 56 2022-06-25 13:56:30,418 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: GV6 to 0 UOM 51 2022-06-25 13:56:30,460 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: GV7 to 0 UOM 51 2022-06-25 13:56:30,529 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: GV8 to 3.0 UOM 56 2022-06-25 13:56:30,623 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: GV9 to 86 UOM 51 2022-06-25 13:56:30,713 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: GV10 to 2700 UOM 26 2022-06-25 13:56:30,818 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: GV5 to 1 UOM 25 2022-06-25 14:00:44,975 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: ST to 0 UOM 51 2022-06-25 14:00:45,067 MQTT udi_interface.interface INFO interface:_message: Successfully set 8cce4e047e10 :: GV5 to 0 UOM 25
Edited by Kevin
It doesn't recognize your bulbs so it doesn't know that they support changing levels.
I just moved MagicHome PG2 to PG3 Node server. It installed, found my LED strips , and I can control them.
It did not install an overall node where the Node server status could be checked. Not sure if that’s by design or it needs to be added but in spirit the Node server is tagged as a beta, I’m reporting it.
Thanks, this was my last PG2 Node server!
Is there any information you would like me to send to you. If you are interested in adding these lights to you node server. Your server dose what I most wanted and that is just to turn them on and off. I can use MagicHome to set the colors and brightness.
Thanks again
Kevin
By design.
You could provide the bulb's manufacturer, model, and specs.
Smart WiFi RGB Fairy String Light, Mowelai Christmas Fairy Light 33 Feet 100 LED, Comptible with Alexa,
Part Number  ‎HL-LEDdengcuan-10M
Brand Mowelai
In there information and on the controller they also refer to it as a Magic Hue smart led
I will keep looking for more information for this controller.
If you think it will help I can order a new one and take it apart and see what chips they are using
Kevin
If you need someone to test anything for you let me know I can try it and send you the log from it.
Kevin
Version 1.0.3 should be in the store now, if you refresh the store you should see it.  Then restarting the node server should automatically up date to version 1.0.3.  Let me know if that work for the LED strip lights.
the effects are working but the percentage is backwards. 1% is fastest and 100% is slowest. also I can not get it out of effects. I tried to set the rgb and huge but nothing changed not sure what would be a good test setting because I have always used a color wheel. I was trying to set rgb 100 and hue 17.
MagicHome_6-26-2022_32242_PM.zip
P.S your node server is listed as production
The MagicHome API isn't documented so everything that works has been reverse engineered and there are still unknowns in the protocol.  It looks like the flux_led project has figure out a lot more since the last time I looked at.
I just added your device type to the list and set it up similar to another device. That could be completely wrong for your device.  It is very possible that the animation speed settings are different for your device.
For my devices, switching to another mode (like setting the on level to something) switches them out of effects mode.  The devices I have support 3 modes, effects, white, and rgb.  Setting the brightness level switches them to white mode.
Node servers have no way to implement a color wheel  control.  Hue changes the color 0 = blue.  Increasing will move the hue towards green, then red and finally back towards blue.   The RGB level is the brightness level, this should effect all three (red, green, blue) leds equally.  So rgb=100% and hue=17 should have been a shade of blue.  But that assumes your devices work the same as the ones I have.
This one has no white just effects and rgb . when I am using magichome andriod app setting a color takes it out of effects. I think on this one you set the colors each. with the app if you don't use the color wheel you cash set red level and blue level and green level 0 - 255.
Just to let you know I am able to do more with your nodes than I was hopping for. I was able to set up my Christmas lights for the 4th of July and run them in a pattern just using the fade to color. I might shorten the time for each pattern and increase the animation speed but it works.
I think that's probably about as good as it's going to get, at least for a while.  I don't have time to try and reverse engineer the protocol differences in the controller you have right now.   So I'm glad it is at least partially working as is.
The only thing I might suggest depending on how hard it is. That is to remove all choices but on off and effects and animation speed. It might save you some questioning of the node server. again Thank you for the node server as it is.
Kevin
