CopyRon Posted June 27, 2022 Share Posted June 27, 2022 In four button position, none of my B buttons work on any of mini remotes, even tried adding new remote same result. Any ideas? Link to comment Share on other sites More sharing options...
lilyoyo1 Posted June 27, 2022 Share Posted June 27, 2022 (edited) 40 minutes ago, CopyRon said: In four button position, none of my B buttons work on any of mini remotes, even tried adding new remote same result. Any ideas? What do you mean they don't work? What behavior are you experiencing What are you trying to do and how do you have them programmed? What is your firmware AND UI? Edited June 27, 2022 by lilyoyo1 Link to comment Share on other sites More sharing options...
CopyRon Posted June 27, 2022 Author Share Posted June 27, 2022 in admin console with isy994i 5.3.4 and with polisy 5.4.4 pressing button b does nothing doesn't even show off or on in console as as buttons A C and D do. Have deleted and reintalled several mini remotes and trid in ISY and Polisy and none of them have a working B button. For now I have moved the controlled devices to a different button and the scene works there. Link to comment Share on other sites More sharing options...
CopyRon Posted June 27, 2022 Author Share Posted June 27, 2022 upon further testing the button actually controls the devices on the A button Link to comment Share on other sites More sharing options...
MrBill Posted June 27, 2022 Share Posted June 27, 2022 Factory Reset is step one. Those can also be reprogrammed between 4 devices or 8 Scene's... see the full manual in the Insteon Cache for more info. http://cache.insteon.com/documentation/2342-x22-en.pdf http://cache.insteon.com/documentation/2342-x32-en.pdf 1 Link to comment Share on other sites More sharing options...
CopyRon Posted June 27, 2022 Author Share Posted June 27, 2022 factory reset cured them all including the one that had never been set up before? Thank you, I guess we should always start in the beginning! 1 Link to comment Share on other sites More sharing options...
