Notification Help
I want to include the Temperature in the attached image in email notifications. When on PG2 this worked in my email notifications:${sys.node.n004_temperature.ST}
Since going to PG3 it does not work. What do I need to change to make it work?
Thank you!
Edited by dbuss
Wrong images
Solved by MrBill
It looks like the node name changed.   ${sys.node.n004_temperature.ST} replace the RED portion with the white text from your screenshot n004_78633 (if I'm correctly reading the screenshot)
Thank you @MrBill. I needed to tweak it a bit more, but you got me on the righ track Here's what works:
${sys.node.n004_78633.CLITEMP}
