Tiny Cloud message
When I login to the ISY Portal I'm getting this message from Tiny Cloud. Can't figure out if it's from UDI or the Microsoft Edge browser. I don't have any association with Tiny Cloud products that I'm aware of. Any ideas?
my.isy.io uses TinyMCE, but this message should not appear.
Could you confirm the URL the browser is seeing when you get that message?
It's either a matter of URL, or tinyMCE API key. If it's not the URL, I'm thinking that a browser extension might be causing problems. You could try to disable extensions and see if one is causing the issue.
Benoit
Here's the URL. It's the same one I've always used. I'll check on the extensions. I don't recall making any changes to my browser but who knows what's going on in the background. This just started, say in the last couple weeks or so.
The URL is correct.
The only thing I can think of would be extensions. I tried Edge myself, and I don't get the error.
You might try with InPrivate, just to see if the cache might be playing tricks.
Benoit
I turned off all extensions and the message went away. I then turned on the extensions, one at a time, but the message never came back. So, it appears to have healed itself. Thanks for the reply. All is good again.
