Z-wave on/off switches with direct association or scenes (to simulate 3-way switch)?
Any recommendations for Z-wave on/off toggle switches which work with ISY and also can be setup so two switches directly communicate to act like a 3-way switch?
We need to add a 3-way switch at the far end of a large room, and with the cost of copper wire today, it's going to cost around a hundred bucks just in materials.   Normally I'd do this with Insteon toggles and an Insteon scene, but this location is Z-wave only.
Anybody successfully setup a pair of Z-wave toggle switches so they directly control each other instead of requiring a program in the ISY to simulate 3-way switching?
Short answer is that there is currently no Polisy support to set up two z-wave switches so they communicate directly and act as a 3-way switch circuit, see this older thread on the subject:
I'm hoping that the new Polisy z-wave interface (coming soon!) will support these features, keeping my fingers crossed...
I have read a thread where it is supported in Polisy but not consistently with all devices and confirm it does with my Zooz hardware.  I tried this week with Zooz gear and could get it to work with the Polisy off, but it was slow....very slow.  And I dont mean a 500 ms slow....Like 10 seconds...Made me think at first it wasn't working.  When I powered back up the Polisy it was instant.
If this is expected behavior I cant recommend it.
I used Basic Scene Ctl 2 on both the responder and the controller.  Then used the option selected below "Z-Wave Basic MC"
I don't understand the protocol enough to know if I did something wrong or if the slow speed was just how it works...but the controller was 10 feet from the responder.  This wasn't a permanent setup, and mainly wanted to test the functionality so I removed the devices from the test scene.
I was using a Zooz:
Zen71(controller) and Zen77(responder)
For the cost of the materials, personally I would recommend "wire in the wall".  It would give a real 3 way if you need it and options later.
Zooz also has direct wire 3 way switches that only need to replace one switch.  The Zooz Zen 77 can do this and there is a non-dimmer version that can work with dumb 3-way switches as well.  The dumb switch just cant change the brightness like the Z-Wave
As I said earlier, I am. I'm using a program to do so.
On:
Foyer Light On - [ID 0031][Parent 0001]
        'Foyer Aux' is switched On
     Or 'Foyer Light' Status is not Off
        Set 'Foyer Light' Fast On
That being said, the OP asked if it can be done without having to use an ISY.
EDIT: 'Foyer Light' in the 'Then' statement is a Scene with the two devices in the 'If' statement in it.
Edited by Athlon
Clarity
At home I use a pair of Insteon switches and a scene to do this, the ISY is aware of the state but the switching of the light isn't dependent on a program running, and is nearly instantaneous.   But this site doesn't have a PLM.
Doing it with a program introduces a dependency I would prefer to avoid.
