Setting up whole house scenes
KenUD
I have a whole house on scene controlled by a keypad. I am trying to add a controlinc to the scene.
It starts setting up but a after a minute or so stops. How do I know what is causing the problem?
Ken
Is it possible you have communication problems? Try a scene test of your scene-in-question. Any indications of problems? Try plugging in your controlinc into the same outlet as your PLM and see if this helps.
Hi KenUD,
In addition to the recommendations by oberkc, I would also like to add the following:
1. Do a scene test on that scene (Tools | Diagnostics | Scene Test). If any devices fail this test, write down their type and version number and post here
2. You can use Event Viewer on Level 3 to see which ones are failing. In releases 2.7.10 and above, you will have an indication of which ones failed through green 0101 icons
      37.5k
      375k
