August 19, 20223 yr @simplextech I hope all is well. Is it possible to add Night mode to the Sonos Node server
August 20, 20223 yr 18 hours ago, lilyoyo1 said: @simplextech I hope all is well. Is it possible to add Night mode to the Sonos Node server I'll look and see if the Jishi API supports it. If is does then yes I can add it. If not then no.
August 20, 20223 yr Author 1 hour ago, simplextech said: I'll look and see if the Jishi API supports it. If is does then yes I can add it. If not then no. Sounds good to me. Thank you
