Cannot toggle output zone status after upgrading to 3.4.9
Solved by AKAPADIA
I have a browser based repro where in one window I do a GET on 192.168.1.213:8080/rest/nodes/n003_output_14/cmd/DOF and in another window a GET on 192.168.1.213:8080/rest/nodes/n003_output_14/ abd the output remains On:
<nodeInfo>
<node flag="0" nodeDefId="output">
<address>n003_output_14</address>
<name>HVAC-Bed 2</name>
<family instance="3">10</family>
<parent type="1">n003_controller</parent>
<type>4.3.2.1</type>
<enabled>true</enabled>
<deviceClass>0</deviceClass>
<wattage>0</wattage>
<dcPeriod>0</dcPeriod>
<startDelay>0</startDelay>
<endDelay>0</endDelay>
<pnode>n003_controller</pnode>
</node>
<properties>
<property id="ST" value="100" formatted="On" uom="78"/>
<property id="TIME" value="0" formatted="0 seconds" uom="58"/>
</properties>
</nodeInfo>
This is working for other Output zones. This only started breaking after I upgraded.
JFYI, I have restarted the Node server and rebooted the polisy multiple times but it doesn't help. In the previous version (3.8.8), every so often (every few weeks) I would bump into this situation where output cmds would stop being honored (even though they would return HTTP 200). I had to reboot the Polisy device to fix. Now, the reboot doesn't work.
Also, there is nothing in the Node server log even when set to DEBUG.
I messed around with the ELKRP - just logged in and deleted the problematic zone and readded it and it seems to have unstuck it. So this seems like an ELK issue..
