Garage Door card with HA
GaryK4
My garage doors use the IOLinc (Relay and Sensor). Has anyone implemented this with Home Assistant? I created a simple card, but the only option I see is a button. That toggles between on and off. However the IO link just want to see an ON every time. In the ISY console, I can start door movement by pressing ON and stop the motion by pressing ON. I can double click the icon in HA, but that is the wrong way to implement it.
How are others handling this?
I don't have any IoLinc's but I do have several cases in HA where the entity for the button is the entity that I want the status of displayed by the button icon.  the button press is "Call Service" to run an ISY program.  Hope that helps.
  • Like 1
HA's ISY integration allows you to create custom devices in HA via ISY programs, so you can make a "cover" in HA that actually consists of programs in ISY that issue the command to the IOLinc and track the status of the door to display in HA.  The program's 'then' logic issues a command to open the door, the 'else' logic issues a command to close the door.
The integration page goes over it and actually has a garage door as an example:
https://www.home-assistant.io/integrations/isy994/#creating-custom-devices-using-isy-programs
I found and modified that code and it seems to work.
type: button
tap_action:
  action: toggle
entity: switch.pool_pump
Then I have a single automation that watches for any switches that I want to be momentary to turn on, and switch them off after .5sec, like this, in automation.yaml
  alias: Momentary  switch
  description: 'Turn any switch into a momentary switch'
  trigger:
  - platform: state
    entity_id: switch.pool_pump, switch.rain_delay2
    to: 'on'
    for: '00:00:00.5'
  condition: []
  action:
  - service: switch.turn_off
    data: {}
  mode: single
      37.3k
      373.6k
