Best way to connect to ISY?
Hello, I have had the ISY994I for years, but since everything is setup I don't connect to the console very often. But when I do need to connect I have to be honest I always have a h*** of a time connecting. Firefox and Edge won't connect to the ISY because Java is not enabled so that means I have to use Internet Explorer which we all know is going away. But that is even a pain. I just tried to connect and it asked me to install the Active X Control and then Windows blocked me from doing it because the address is intrusted. This is so frustrating every time I go in I run into this and then I forget how I got in the last time. Am I doing something wrong here? Please tell me there is a HTML 5 version that has eliminated the need for Java??? Am I doing it the old way and things have changed? Any help would be appreciated. Also can you post a link for a new user guide as I might be doing this an old way. Everything is still working though :) Thanks.
Please read the wiki for the steps you need to perform:
https://wiki.universal-devices.com/index.php?title=Main_Page#Installing_the_Admin_Console_Icon_on_Your_Desktop
In 2018 the process changed to use what is called ISY launcher so it is not dependent on any browser being needed to launch admin Consol. All you need is a standard version of Java that you download directly from java.com. Make sure that you clear Java cash before proceeding on any steps in the above wiki.
