Venstar Thermostat + V2 Adapter
I've upgraded to the Insteon V2 adapter, but I kept my ISY on v2.7.6 while the releases stabilize a little. I was assuming that everything should be backwards compatible and that ISY should be able to correctly operate the adapter without taking advantage of the newer features - is that correct or do I need to move to a new rev?
I'm noticing issues with my T1700 Thermostats in my Family Room (I also have a T1900 in my Living ROom which seems more stable). It appears to be operating randomly and the log to me is nonsensical. Note I've done the thermostat humidity fix (though it's currently showing 109%!) - I actually have my suspicions about the thermostat itself.
Below is my log. I have a program set to run at 6pm which will try twice to set the temperature of both thermostats (Liviing Room=68, Family Room =69). The log values seem suspicious- or is that because of my ISY rev?
Living Room - Thermostat Thermostat Mode Heat Sat 02/13/2010 06:00:00 PM Program Log
Living Room - Thermostat Heat Setpoint 68░ Sat 02/13/2010 06:00:02 PM Program Log
Living Room - Thermostat Setpoint 136 Sat 02/13/2010 06:00:02 PM System Log
Living Room - Thermostat Heat Setpoint 68░ Sat 02/13/2010 06:00:02 PM System Log
Family Room - Thermostat Thermostat Mode Heat Sat 02/13/2010 06:00:05 PM Program Log
Family Room - Thermostat Setpoint 32 Sat 02/13/2010 06:00:06 PM System Log
Family Room - Thermostat Heat Setpoint 16░ Sat 02/13/2010 06:00:06 PM System Log
Family Room - Thermostat Heat Setpoint 69░ Sat 02/13/2010 06:00:06 PM Program Log
Family Room - Thermostat Setpoint 138 Sat 02/13/2010 06:00:07 PM System Log
Family Room - Thermostat Heat Setpoint 69░ Sat 02/13/2010 06:00:07 PM System Log
Living Room - Thermostat Thermostat Mode Heat Sat 02/13/2010 06:00:11 PM Program Log
Living Room - Thermostat Heat Setpoint 68░ Sat 02/13/2010 06:00:12 PM Program Log
Family Room - Thermostat Thermostat Mode Heat Sat 02/13/2010 06:00:16 PM Program Log
Family Room - Thermostat Setpoint 124 Sat 02/13/2010 06:00:17 PM System Log
Family Room - Thermostat Heat Setpoint 62░ Sat 02/13/2010 06:00:17 PM System Log
Family Room - Thermostat Heat Setpoint 69░ Sat 02/13/2010 06:00:18 PM Program Log
Family Room - Thermostat Setpoint 138 Sat 02/13/2010 06:00:18 PM System Log
Family Room - Thermostat Heat Setpoint 69░ Sat 02/13/2010 06:00:18 PM System Log
Living Room - Thermostat Status Query░ Sat 02/13/2010 06:07:55 PM Program Log
Family Room - Thermostat Status Query░ Sat 02/13/2010 06:08:05 PM Program Log
Family Room - Thermostat Status 66░ Sat 02/13/2010 06:08:06 PM System Log
Family Room - Thermostat Setpoint 124 Sat 02/13/2010 06:08:07 PM System Log
Family Room - Thermostat Heat Setpoint 62░ Sat 02/13/2010 06:08:07 PM System Log
Living Room - Thermostat Status Query░ Sat 02/13/2010 06:18:05 PM Program Log
Family Room - Thermostat Status Query░ Sat 02/13/2010 06:18:15 PM Program Log
Family Room - Thermostat Status 67░ Sat 02/13/2010 06:18:15 PM System Log
