8GB SD Card -- Seen as only 4GB
bachguy40
I recently replaced my original SD Card with an 8GB card. I followed all of the procedures outlined in the user guide .pdf and all is working successfully. I even copied all of my web files and folders (I have the networking module) with no problems. I am using firmware 2.7.10
When I check Tools--> Diagnostics -->File System status, the total reads 3665 MB.
I have checked the SD Card with my pc's card reader, and it is indeed an 8GB card.
Have I done something wrong? How do I get the diagnostics to see all 8 gigs?
Thanks in advance for any help you might provide!
--Frank
  • 6 months later...
I am sure because of the age of this post it may be no longer an issue, but I would like to double check with you and make sure you moved up to at least the 2.7.15 firmware release because I think this was fixed by then.
      37.8k
      377.5k
