Problem Setting up Polisy on UD Mobile (Local network only)
I'm trying to add my Polisy to my UD Mobile app on Ios 15.7  as a local network connection - not via portal.
I DO NOT use the ISY Portal, I only use Local Network access (I use a VPN when away from home)
When I try to add the Polisy local IP address (https://192.168.x.xx and port 8443) and test, I get an error that the IP address must begin with HTTP, not HTTPS.
When I enter the IP address as HTTP://192.168.x.xx and port 8443, I get an error that the "App transport Security Policy requires use of a secure connection"
Using various related URL's such as http://polisy.<privatedomain.pvt>, adding /desc at the end of the URL, and/or adding port to URL or not, letting UD Mobile try to connect to Polisy on Port 80 as http -  all result in one of the same two errors.
Anyone have a way around this seemingly Catch-22 issue?
Polisy is running Ver 5.4.4
UD Mobile version for Ios is Ver 0.9.2
Again - I do not use the portal. All connections are via local network only.
Note: UD mobile works fine in this config with my ISY's - but not in secure transport - as HTTP only.
Edited by Craigb
clarity
Solved by tazman
