Notification NS - sys short - Network substitution variables not working
@Jimbo.Automates, I noticed my notifications coming through do not include actual data just the outline for what the message  should be.  This use to work:
Notify Test sys_short - [ID 00C9][Parent 007A]
        'Greatroom / Ecobee Controller' Node server Online is Disconnected
     Or 'Greatroom / Ecobee Controller' Node server Online is Connected
        Set 'Notifications / Notification Controller / Service Pushover HomePush' Device Tims_Phone
        Set 'Notifications / Notification Controller / Service Pushover HomePush' Priority High
        Set 'Notifications / Notification Controller' Short Custom Content 16 Notfiication ID
        Set 'Notifications / Notification Controller / Service Pushover HomePush' Send Sys Short (old from controller)
There are a 2 other choices for the send command, the one above is the only one that does anything.  The others send no notification at all:
Send Sys Short with Params
Send Sys Short
Did something change?  Thank you
Update:
I also tried this version of the program, same result, no data in notification.  However the Send Sys Short does send a message.  I noticed there was an error in the log 'Message is blank" so that was why I changed the program.
     Or 'Greatroom / Ecobee Controller' Node server Online is not Disconnected
        Set 'Notifications / Notification Controller / Service Pushover HomePush' Short Custom Content 16 Notfiication ID
Edited by tmorse305
Update:
I don't think this is a NS problem but more fundamental with IoP.  I'm going to create a new thread to see it anyone else is seeing this problem
