Blink NS - Cannot install
Hi @Panda88, I tried to install the node server(trial) but I get an error, see attached.  The NS actually looks like it installs.  It appears on the dashboard but only for a few minutes but then disappears as though it was never installed.  The process is repeatable.
Suggestions?
Update.  I tried to restart PG3 to see if it would make a difference, it did not.  PG3 log attached from PG3 reboot.  I see 1 error related to Blink:
10/12/2022, 19:27:01 [pg3] error: createNS: ReferenceError: status is not defined
    at checkLicense (/var/polyglot/node_modules/@universaldevices/pg3/lib/services/node servers.js:688:95)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async Object.createNs (/var/polyglot/node_modules/@universaldevices/pg3/lib/services/node servers.js:451:5)
log from boot.zip
Edited by tmorse305
More information
Solved by tmorse305
