Blink NS New camera type?
Hi @Panda88, I install the Blink NS and am not sure I have it configured correctly.  I have a Blink XT2 which may be a camera model that you haven't incorporated yet.  I attached the log after updating the camera.
I have a Sync module but the NS could not find the camera when I enter the name 'Sync Module' in the configuration.  I didn't give the Sync Module a new name in fact I'm not sure that's the name, I don't see any way to change it in the Blink app. When I tried 'NONE' it found the camera.  It is partially working, the temperature seems to be correct, but I cannot control the Arm Status.  I can change it in the AC but it does not change the actual camera status.
Thank you for developing this NS!  Using it will allow me to eliminate a work around using a Hubitat to allow IoP to monitor camera status
Blink_10-13-2022_94051_AM.zip
Solved by tmorse305
Thank you @Panda88 for fixing this in version 0.3.1!
For anyone else trying to use this, the name of the sync module is the name you assigned to your Blink system.
Edited by tmorse305
