Rain Machine NS Stops After a Restart
@glarsen,
I noticed recently I wasn't getting any updates in UD Mobile for RainMachine, so I restarted the node server.  It appeared to restart and then immediately stopped.  Attached is the log package showing the errors.  I'm running IoP 5.4.4 and the PG3 3.1.11.
RainMachine_10-17-2022_80819_PM.zip
Solved by mbking
It looks like there's already a copy of it running on that slot.  Probably when you updated and restarted PG3, PG3 wasn't able to stop the node server so now it won't let you start another copy.
Either ssh to the polisy and kill the existing rainmachine node server process or reboot the Polisy.
@bpwwer, I rebooted Polisy, but had to also restart each node server.
After the reboot, all but the RainMachine NS showed Disconnected.  The RainMachine NS showed Connected, but wasn't running.  After restarting all of the NS's, operation appears normal.  Not sure why each had to be restarted, but the reboot and restart did the trick.
Thanks for your help!
