Is there documentation for ST-Sonos?
I'd love to be able to send commands to my Sonos Controller from ISY programs. I think this Node Server probably has that ability. The problem I am having is that I can't find and documentation of the command structure. I suspect form the limited instructions in the Node configuration that I can do this using a TTS phrase and a value.
I have no idea what values are allowed, their parameters, or syntax.
Can someone direct me to this information??
Solved by bpwwer
I don't have this node server installed and don't have any Sonos devices, so I may be completely off base here.
Typically the commands a node server can send to a device are predefined. To use them in a program you go into the program interface and select 'Control' for the 'then' part of the program and select the specific node server as the device.  It should then have a drop down list of the commands you can send to the device.
Following the links to the node server documentation  https://github.com/simplextech/pg3_docs/tree/main/ST-Sonos
says it supports all the functionality of the API which lists the following:
The actions supported as of today:
  • play
  • pause
  • playpause (toggles playing state)
  • volume (parameter is absolute or relative volume. Prefix +/- indicates relative volume)
  • groupVolume (parameter is absolute or relative volume. Prefix +/- indicates relative volume)
  • mute / unmute
  • groupMute / groupUnmute
  • togglemute (toggles mute state)
  • trackseek (parameter is queue index)
  • timeseek (parameter is in seconds, 60 for 1:00, 120 for 2:00 etc)
  • next
  • previous
  • state (will return a json-representation of the current state of player)
  • favorite
  • favorites (with optional "detailed" parameter)
  • playlist
  • lockvolumes / unlockvolumes (experimental, will enforce the volume that was selected when locking!)
  • repeat (on(=all)/one/off(=none)/toggle)
  • shuffle (on/off/toggle)
  • crossfade (on/off/toggle)
  • pauseall (with optional timeout in minutes)
  • resumeall (will resume the ones that was pause on the pauseall call. Useful for doorbell, phone calls, etc. Optional timeout)
  • say
  • sayall
  • saypreset
  • queue
  • clearqueue
  • sleep (values in seconds)
  • linein (only analog linein, not PLAYBAR yet)
  • clip (announce custom mp3 clip)
  • clipall
  • clippreset
  • join / leave (Grouping actions)
  • sub (on/off/gain/crossover/polarity) See SUB section for more info
  • nightmode (on/off/toggle, PLAYBAR only)
  • speechenhancement (on/off/toggle, PLAYBAR only)
  • bass/treble (use -10 thru 10 as value. 0 is neutral)
Is there something beyond that you need help with?
Thanks. Not exactly what I was seeking, but tracking through some of the links you provided got me enough hints to get the node working. For some reason I hadn't been able to find those links even though I was on the same GitHub section.
Again thanks.
