Lamplinc replacement
I just had a Lamplinc go bad on me so I replaced it (2456D3) I drop it into one of my scenes and it works fine, except it is on 100% or fast off -- the settings I make in the scene don't seem to work from the controller (KPL) If I turn the scene on and off from the computer it works fine and will ramp at the speed I set it to and level? Am I doing something wrong? I have not had to do much with my network for a couple of years and I may have forgotten something?
FYI I am using the ISY26
Glenn
Hello Glenn,
Within the scene select the KPL as the controller. Then adjust the level and rate or Copy Scene Attributes.
Rand
That did it -- Thanks Rand. When something works this well you forget how you set it up -- I guess that's the sign of a good stable system!!
