MClarke Posted November 27, 2022 Share Posted November 27, 2022 I set up AmbientPoly on a Raspberry Pi and everything seems to work initially. After some period of time (24 to 48 hours) it stops reporting data. The node server still shows "connected" during that time and restarting the node server will fix the problem. The error log is below: 2022-11-27 00:56:04,656 Controller polyinterface ERROR polyinterface:write: Exception in thread Controller: Traceback (most recent call last): File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner self.run() File "/usr/lib/python3.7/threading.py", line 865, in run self._target(*self._args, **self._kwargs) File "/home/pi/.local/lib/python3.7/site-packages/polyinterface/polyinterface.py", line 854, in _parseInput self.longPoll() File "./ambient-poly.py", line 184, in longPoll self.set_driver(node, 'GV1', d, 'windgustmph') File "./ambient-poly.py", line 206, in set_driver report = True, force = self.first_poll) File "/home/pi/.local/lib/python3.7/site-packages/polyinterface/polyinterface.py", line 683, in setDriver self.reportDriver(d, report, force) File "/home/pi/.local/lib/python3.7/site-packages/polyinterface/polyinterface.py", line 704, in reportDriver self.controller.poly.send(message) File "/home/pi/.local/lib/python3.7/site-packages/polyinterface/polyinterface.py", line 385, in send self._mqttc.publish(self.topicInput, json.dumps(message), retain=False) File "/home/pi/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 1258, in publish local_mid, topic, local_payload, qos, retain, False, info, properties) File "/home/pi/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 2693, in _send_publish return self._packet_queue(PUBLISH, packet, mid, qos, info) File "/home/pi/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 3016, in _packet_queue return self.loop_write() File "/home/pi/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 1577, in loop_write rc = self._packet_write() File "/home/pi/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 2465, in _packet_write packet['packet'][packet['pos']:]) File "/home/pi/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 649, in _sock_send return self._sock.send(buf) File "/usr/lib/python3.7/ssl.py", line 984, in send return self._sslobj.write(data) ssl.SSLEOFError: EOF occurred in violation of protocol (_ssl.c:2341) Any thoughts? Link to comment Share on other sites More sharing options...
