PG3 and Hue Node Server can't find any Hue Hubs
I just upgraded to PG3 Version 3.1.15 on my Polisy Pro over the latest PG2 version.  I also migrated my ISY994 to IoP 5.4.5.  I installed the new production Hue node server 0.1.11 on PG3, reboot everything.  After coming back up and implementing with the Hue hub button press and restart node server in less than 30 seconds it cannot find any Hue hub servers.  I'm dead in the water here.  Was working fine on PG2 and ISY994.  Is it possible there are new instructions for adding Hue hubs under PG3?
From the Hue log file...
The highlighted seems to point to the problem....
2022-12-03 16:30:41,174 Thread-1   udi_interface      INFO     phue:connect: Attempting to connect to the bridge...
2022-12-03 16:30:41,175 Thread-1   udi_interface      INFO     phue:connect: Error opening config file, will attempt bridge registration
2022-12-03 16:30:41,187 Thread-1   udi_interface      ERROR    hue:connect: IP Address OK. Node Server not registered.
2022-12-03 16:30:41,189 Thread-1   udi_interface.custom INFO     custom:_save: Sending data notices to Polyglot.
2022-12-03 16:30:41,274 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = notices
2022-12-03 16:30:41,277 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = notices
2022-12-03 16:30:41,424 Thread-4   udi_interface.interface INFO     interface:updateProfile: Sending Install Profile command to Polyglot.
2022-12-03 16:30:41,427 Thread-4   udi_interface.custom INFO     custom:_save: Sending data notices to Polyglot.
2022-12-03 16:30:41,647 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = notices
2022-12-03 16:30:41,889 MQTT       udi_interface.interface INFO     interface:_message: Profile installation finished
