Unable to upgrade to version v1.0.6 from v1.0.5
@simplextech, I don't know if this is a node server issue or a general PG3 issue, but restarting the node server does not perform the upgrade from v1.0.5 to v1.0.6.  Several restarts of the node server, and no joy...
Solved by Jimbo.Automates
Had a similar issue. Had to delete then reinstall the NS in the same slot. My programs remained intact but had to edit and save them in the ISY to make them work again.
This is a bug in PG3 where it doesn't properly recognize a new version of a node server that was previously released with a very old version of PG3.
But, do not delete and reinstall. You can reinstall in the same slot from the store or purchases page.
Sent from my Pixel 6 Pro using Tapatalk
Right you are!  I never bothered to look, so thanks for this tip.
