Polisy zMatter supported Recessed RGB lighting
I just received my ZMatter board to be installed in the Polisy.  I would like to install recessed RGB Can lights using the Zigbee interface.  What light brands (preferably from Amazon) does it support natively? Or,  do I still need some kind of hub (e.g. hue hub) which I assume doesn’t even take advantage of the new card?  I’m ok using resources but prefer a Node server.  Any recommendations how I could go about this?
Being that this is a brand new board for everyone (everyone is still waiting on the firmware update for it as well), most likely you'll be the trailblazer on this one. I'd google zigbee rgb recessed bulbs. As long as they support the latest zigbee HA, you should be fine. I say should because its not something i've tested so I cant say definitively.  If you look in the PG3 Node Server subforum, you'll see all currently supported node servers.
Edited by lilyoyo1
