IFTTT set up
Just installed IFTTT and setting things up, getting this error:
 Not Found: https://maker.ifttt.com/trigger/Ewelink/with/key/https://maker.ifttt.com/use/API_KEY
every variable is named Ewelink
Applet, Event Name in IFTTT
Node Address , Node Name  and Off Event Name  in Polyglot ,
What am I doing wrong?
Solved by tmorse305
Do you have the API key configured correctly?  It looks odd in the error message above.
From Jim's instructions:
API Key
Enter your API Key for Webhooks by going to Maker Webhooks then click on Settings. This shows a line at the bottom like https://maker.ifttt.com/use/xxxxxx the xxxxxx is your API Key. Copy and paste just that part to the API Key.
It looks like you included the https://maker.ifttt.com/use part.  Just enter the xxxxxx part.
A typical key looks something like this: duC-0KVspL2ctf2jpgPEs1
Edited by tmorse305
