Can't find new device I added
I just added a new device – an Insteon lamp module – to my ISY994. On version 5.3.4 of both firmware and Admin Console. The device is 35.0D.08 L:ampLinc BiPhy V 4.3. Added it, no problem. But, in the list of devices in the Admin Console, I can't see it to link it. I tried adding it again, but the Admin Console insisted it was already there. Restarting the Admin Console didn't help. Is there some way I can delete it and add it again if I can't see it in the list in the Admin Console? --Puzzled in Pittsburgh
P.S., Why do I have to do a ReCaptcha every 15 seconds?
Solved by KConover
Glad you got your device issue figured out.
Where are you seeing this? On the forums? Are you on a computer or mobile device and how are you accessing the forums? If you have any plug-ins that block cookies it might be causing you an issue.
This was as I was accessing the forums and writing the above. I was in a Firefox browser tab. I ended up simply creating my post in an ASCII editor and then pasting it into the window so I only had to Recaptcha once.
