Another connection issue
Just upgraded from PG2 to PG3 (trial).  It was working nicely on pg2 but I cannot get a connection to the Envisa from PG3 - I can log in via browser without issues
Any suggestions - I cannot find anything in the log file but you may see something
debug.log
thanks
There was an issue when installing - I was asked if I wanted to install in in the existing slot(PG2) - I said yes - and after that both pg2 and pg3 showed the node.  I deleted the PG2 node but it did not solve the issue
From what I can see in the log, it is trying to connect to the Envisalink  at 192.168.1.251. Not ever getting to login because the initial socket connection is being refused:
evltpi_dsc:_get_next_cmd_seq: TCP Connection to EnvisaLink unexpectedly closed. Socket error: [Errno 54] Connection reset by peer
The "connection reset by peer" error message has normally been the result of another connection to the Envisalink, e.g. another version of the node server, NodeLink, or some other controller connected to the Envisalink.
If you know there is no longer another process running somewhere that is connecting to the Envisalink, then I would suggest using the web interface of the Envisalink (http://192.168.1.251) to go to "Network" settings then click "Reboot Envisalink."
Edited by Goose66
thanks
Let me check - In the past I had issues with rain machine devices attaching to the envisalink - It is just strange it worked until changed to PG3
Also - I can log into device from browser, but it may be a different connection type
I wonder if my router/firewall updated FW and somehow blocked the port (on the LAN side) - I did submit a question there as well
Are the Polisy and EnvisaLink on the same LAN? If so, then the router/firewall wouldn’t come into play. Also, if the node server couldn’t reach the EnvisLink you would get a timeout on the connect. What’s happening is the node server is connecting to the EnvisaLink and the EnvisaLink is immediately resetting the connection. I’ve only ever seen this when there is another connection to the EnvisaLink.
