POLISY PKG Endless Loop
Beaker
Go to solution Solved by Michel Kohanim,
I recently attempted to perform a package update on Polisy. After kicking of the process via the
IoP console I waited aprox. 30 minutes, SSHed into the Polisy to find that the process was still
running. Seemed odd that it hadn’t completed, I kicked off the following cmd ‘sudo tail -f /var/udx
/logs/log’ to find the pkg upgrade process in an endless loop. It was basically complaining that the
pkg command itself had to be upgraded first but it was not taking place and continued to loop. I’ve
posted a snapshot of the above noted log. The below block of text continued to fill the log file.
Any assistance would be great.
Cheers,
Ken.
Updating FreeBSD repository catalogue...
FreeBSD repository is up to date.
Updating FreeBSD-base repository catalogue...
FreeBSD-base repository is up to date.
Updating udi repository catalogue...
udi repository is up to date.
All repositories are up to date.
New version of pkg detected; it needs to be installed first.
Checking integrity... done (0 conflicting)
The most recent versions of packages are already installed
Link to comment
Beaker,
I am so very sorry to hear. Please do either of the following:
1. In /usr/local/etc/pkg/repos/FreeBSD.conf, add priority: 1. Something like this:
FreeBSD: { url: "pkg+http://pkg.FreeBSD.org/${ABI}/latest", enabled: yes, priority: 1 }
2. Do:
sudo pkg install -r udi pkg
sudo /usr/local/etc/udx.d/static/udxops.sh upgrade.polisy
  • Thanks 5
Link to comment
      36.8k
      369.9k
