Support for ZMatter Board
shbatm
To the UDI team, maybe  @Michel Kohanim can answer this (Sorry to tag you directly but I don't think that this is going to be public knowledge, so I'm coming to the source...)
I am trying to update the PyISY python package to support the new ZMatter board after a user reported getting errors loading Home Assistant here
I can trace it back to how HA is differentiating Z-Wave vs Insteon nodes via the family code in the rest results. I see that Z-Wave on the new board is using a Family code of 12 instead of 4. Is that just for Z-Wave on the new board? Is Zigbee/Matter using anything different (e.g 11)?
Has anything else changed on the REST side for the new board or Node structure?
Asking so I can build in as much support as I can now without just being reactive to users running into errors.
@shbatm, thanks so much for starting work on this so quickly after I reported the issue.
@Javi Thanks for the leads! This will help.
I didn't see anything about the family code for the primary node endpoints (e.g. /rest/nodes and /rest/node/ZY_xxx)
<family>12</family>
Just want to confirm if Matter/Zigbee is going to be 12 as well or if it will use 11 (or something else)? Thanks!
<family>12</family>
At least the ZWave part of ZMatter is family 12, not sure about Matter.  Most of the legacy Zwave paths (i.e rest/zwave/xxx are migrated to zmatter path. (i.e rest/zmatter/zwave/xxxx)  so rest/nodes and rest/nodes/xxx remain the same
  • Thanks 1
      37.5k
      375.5k
