Polsy on isy 994 -> v5.3.2
So I was working toward getting a node.js + ambient weather going... and I decided to check latest firmware.  I see I am running v5.3, and v5.5 is out.  I also see v** has been renamed to Polisy.  I read the docs on how to upgrade to 5.5, and they appear to cover just polisy.  The suggestion of going to Configuration -> Update does not exist.  I only have one option anywhere, thats to manually update firmware.
I tried to look for perhaps 5.4 as some middle-ware.  Couldn't find it.
Does anyone have a simple howto on how to go from v5.3.2 (On my Isy994i) to the start or latest polisy?  Thanks in advance!
I see you said polisy hardware….. I want to update my isy 994.  Is polisy a different piece of hardware?
Currently, there are three controller hardware versions, ISY994, Polisy, and the just released EISY
The current firmware version for the ISY994 is 5.3.4, that's assuming that you don't have the Zwave module installed.
What's your current firmware and UI versions?
The node servers require either the Polisy or EISY hardware
Edited by Techman
I do have the isy, and the latest (ordered online) zwave module.
Should I replace it with a polisy?
You'd need to replace it with eisy
