Add IoX to PG3
After inadvertently deleting eisyIOX from the ISYs in PG3 I am unable to add it back. I did a factory reset but it is still not showing up. Did the add ISY with all the parameters but no luck. Did this countless times. Any suggestions appreciated.
Thanks Gary
Got it working again. After giving it a new reserved IP address it started right up and is now working. Although I could always connect to the AC. Now on to the conversion.
Not Working again. After a reboot to add Insteon support PG3 again will not load the local ISY. There seems to be some sort of IP addressing issue between PG3 and IoX.
Edited by garybixler
