Where are the Fx Keys for all the Keypads
Hello there;
Migrating from ISY on PG2 to IoP to PG3... bought the ELK NS, but am having a hard time making sense on accessing the keypads.
Is there a manual somewhere? Or, at a minimum, can someone tell me how to find the Funcion keys?
Cheers
2 hours ago, TriLife said:
Hello there;
Cheers
When you are in the production store, there is a button that says "more info". Pressing that button will take you to the instructions. Here is a link:
https://github.com/UniversalDevicesInc-PG3/udi-poly-ELK/blob/master/README.md
There is also a log for open issues here:
https://github.com/UniversalDevicesInc-PG3/udi-poly-ELK/issues
As for F keys, there is some functionality, but there is an open issues that you can read about here:
If you are having an issue, use ElkRP rule to set an output when the F key is pressed, then in Polisy, have a program run when the output turns on/off.
